Currently I'm living in an apartment that has poor soundproofing. My upstairs neighbors get up at 4:30 am to go to work. They have two dogs. So there's a lot of noise between 4:30 am and 5 am. Like any sane person, I don't want to wake up at 4:30 am.
I've had many issues with noise in this apartment so I'd like to solve the issue at the source.
Is there an effective way to soundproof a ceiling that's not permanent? Inexpensive would be great too. I'd like to put less than $200 into the whole endeavor if possible.
  • 20,909
  • 95
  • 135
jcollum
  • 153
Ridged foam insulation might work here. It comes in large pieces and is lightweight enough that it won't take many fasteners to hold it up (so you'll have less nail holes to fill when you leave). The downside of course is that it isn't very pretty.
  • 20,909
  • 95
  • 135
boxed-dinners
  • 1,095
You need to put up a layer of sound absorbent material between you and the source of the sound.
A permanent solution would be to add a false ceiling of "sound proof" plasterboard with possibly additional sound absorbing material between it and the real ceiling. However, this isn't suitable in this case.
The only non-permanent thing I can think of is that you attach some reasonably heavy duty material (curtain or blanket type) to the ceiling. You'd still might need to attach some form of battens to the ceiling to anchor the material though.
ChrisF
  • 16,973
  • 74
First find out the areas that are the most noisy, then you can think about investing money on soundproofing. Better solution is, put down area rugs in your highly trafficked surrounding.
margareta
