My wife & I renovated our master shower a couple years ago. About three months ago, we noticed the baseboards in the guest bathroom (on the other side of the wall from the master bath) were getting water damage (similar to how they were getting damaged a couple years ago, thus the shower remodel). I tore out the baseboards & sure enough, water was showing up just like it did a couple years ago. I called my contractor friend out to look (he had spear-headed the original remodel) & his thoughts were that it wasn't leaking thru the tile/hot-mop since none of our tiles were displaced or coming off. So I tested - I plugged the drain & filled the shower with water. It held water for 6-8 hours without any showing up in the guest bathroom, but as soon as I took a shower, there was the water! This made me think it was the drain under our slab, but how was the water getting up?
Here is what I think is happening, but I would like some thoughts on how to remedy it without tearing up my newly-remodeled shower. I think the Fernco adapter mating the original cast iron pipe with the new PVC pipe is leaking. Of all of the pictures I took during the remodel, one of them showed the plumber didn't clean up the cast iron pipe before attaching the Fernco adapter. I believe this joint is leaking, the soil around this joint is now saturated and the water is being forced up thru the slab at the point where the vent pipe goes thru the slab. I called a company that does pipe relining, but they wanted $1800 for this three foot run and wouldn't guarantee a seal since they were getting to the problem area thru the shower trap. I do need to get a couple more estimates, but at this price it might just be cheaper to tear up the shower floor & fix it correctly, thereby confirming the problem & guaranteeing a fix.
Does anyone have any other ideas as to how to fix it? I'd appreciate any thoughts.
Aarthi
  • 1,143
Dave Mc
  • 71
It's possible the water is getting around your shower, possibly where the tile meets the tub or pan (if you have one), or behind the fixtures, or even around the door (if any).
I would check all of these and recaulk where appropriate before going in for wholesale destruction. Try splashing water by hand/bucket on areas you might suspect and see if that leads to leaks.
Or maybe you even have leaky plumbing in the wall. Do you have access to see in there?
Alex Feinman
  • 3,532
If your shower isn't sealed behind the tiles the water can leak past the tile and grout down into the space. Very common as most builders only use green board and put tile up over the top. This is asking for troubles down the road.
The drain could also be leaking as you believe. In that case plug the drain at the surface and take a shower. If you see water then you know it's coming from the walls and tile leaking. May be good to open up the wall so you can see the water seeping. If no leak from the shower - empty the pan by removing the drain plug. If it now leaks you know the source of the water.
J_austin
Obviously it is a leak where the drain opening and tile meet, the seal is somehow bad. I say this because I just had this happen to myself, after renovation. I realize your situation is resolved, and you don't need input, but those who still Google this problem may benefit.
I discounted a leaky source and drain pipe all in one move. I took the drain cover off, put the garden hose down the pipe past the opening, and no leak. I put the hose outside the drain and there was a leak.
Time for a new coupling/grommet.
  • 20,909
  • 95
  • 135
David Kay
Nice one, Dave! It is good that you detected the leak earlier before it caused more damage. Many homeowners don't realize they have a potential slab leak situation until some major damage occurs to the home, like floor damage and heating problems. One of the causes of slab leak is hard water - a combination of water, lime, calcium and iron in the water and pinhole leak of pipes under the slab. To prevent the leak, fix the pipes under the concrete slab and replace rusting pipes. Seek the help of a professional plumber to assess the gravity of the slab leak. Good luck!
