I have 4 120 V 20 watt LEDs. I want to put them over my desk. They are the Lusa Lighting Model #33000 (If you want to see the PDF). They come with plugs so you can plug them in separately. I want 1 plug for all 4 of the LEDs and I'm wondering if it is safe to wire them in parallel.
I read that wiring LEDs in parallel draws more current and since I'm plugging all 4 into the same socket I don't want to put stress on it. I live in the U.S so our outlets supply 15 A of current. If I did my math correctly each one would only draw (20W / 120V) = 166 mA with a total of 664 mA.
Please tell me if this is safe and if I did my math correctly.
  • 20,909
  • 95
  • 135
Based on the Lusa Lighting Model #33000 which are sold under Hampton Bay brand #148652 (For the 3 Bulb White kit), these are not LED lights. They are straight Halogen Light Fixtures.
Each of the Light is a standard 120V Halogen Bulb in a fixture, wired with a standard 2-prong outlet plug. The kit comes with a basic 3 to 1 power strip.
If you have 4 lights, 80W / 120V = 0.667 Amps, you can just use your own power strip instead of the included one. If you have 4 kits of 3, you need up to 12 outlets. Even with 12 20W fixtures, that is still only 240W, or 240W / 120V = 2 Amps.
You could wire them in parallel, but a Power Strip already does this for you, and is safer than wiring it yourself if you are not experienced.
Otherwise see How to connect multiple light fixtures to one switch?
cde
  • 745
