I am considering renovating my house, that will be turned into a small student housing (approx 10 - 15 people).
I would like to know what is the most efficient way to build a septic tank to dispose all excrement.
Ideally, the tank should be:
  1. Relatively cheap
  2. Simple and Easy to build
  3. Easy to be emptied (pumped out)
  4. Able to contain the smell
  5. Should there be any leakages, it should be easy to repair.
  6. Easy to inspect (to check if it needs to be pumped out)
  7. Does not contaminate ground water, as I also use ground water as the source of water (Where I live, clean water pipeline is not an option. So I have to drill a well myself to extract the water. Thankfully, I live in the area that has a high rainfall).
Can any one give me advise or perhaps a reference on this? I've been looking on the web and these are some of the ideas that i have so far:
  1. This one has a calculator on how big the tank should be depending on the # of occupants.
  2. Is this a good design reference? Can anyone explain what is the purpose of each label
Jeremy
  • 121
0 Answers0
