I'd like to know if there's an argumentation-/science-based recommendation regardless of the specific laws in different countries. Boundaries/parameters of my question:
  • fire pit for making a(n open) camp fire with wood for <= 15 persons (max. 10 kg of wood burning at the same time[1]) on the ground inside a stone circle
  • building made partly or completely of wood (I guess that matters, so should be distungished in the formular in the answer)
  • fire is watched permanently
The choice of the distance should avoid transmission of sparks to fire receptive parts of the house, e.g. exposed parts of the root framework. What would a fire fighting specialist/consultant, assurance specialist, etc. say?
[1] I've no idea how to measure fire energy emission, so I give this "dimension" for the beginning
Kalle Richter
  • 247
The model building codes provide separation distances based upon radiant heat, construction type, occupancy, fire resistance of the exterior walls and the ratio of openings to solid wall in the building to be protected.
Keeping in mind that the fire separation distances given are in feet from the property line and that adjacent buildings have similar requirements one could use the combination of IBC [2009] table 602 and table 705.9 to determine separation. As a rule of thumb, 60' would be the maximum required between two buildings each located 30' from the property line.
However, I recommend discussing the issue with your local fire official. There may be additional considerations that limit or prohibit the use. The fire official may also be aware of additional environmental, utility infrastructure, or fire service availability factors that increase or decrease the risk associated with a large fire pit.
If you set the forest ablaze, the distance between the pit and the structure will become irrelevant.
I think the most important aspect is the possibility of a long lived spark being blown to the house where it might contact cedar shingles or the like.
When burning dry firewood like western white pine or doug-fir, the longest lived sparks which I have observed last 5–7 seconds after which they are effectively extinguished.
Using seven seconds then depends on the maximum windspeed. Most people aren't interested in hanging around a campfire when the wind is much over 15 mi/hr (24 km/h) so using 20 mph (32 km/h) means the distance to a valuable burnable object should be 205 feet (63 m) minimum.
However, I have assumed quite a bit. To apply to other situations, adjust:
  • Lifetime of spark
  • Wind speed
  • Safety factor
wallyk
  • 12,399
I don't have a specific formula for you (I don't see how you could derive one), but I will say that in general engineering tolerances are a balance between two factors:
  • How likely is something to happen?
  • How bad would it be if it did?
This is why buildings in earthquake-prone areas are built stronger than elsewhere (because an earthquake is more likely to happen there), and why hospitals are built more strongly than single-family homes (because a hospital collapsing is worse than a single house collapsing).
So in this case you would need to weigh how likely you feel the fireplace is to start a fire (which depends on how big a fire it is, what kind of hearth you've built, wind speed and direction, etc.) vs the consequences of an uncontrolled fire (is the building just a shed or a multi-family house? Do you have a hose nearby in case a stray ember lights something?).
Hank
  • 14,213
  • 46
  • 48
NFPA considers 35' to be the default distance from areas where sparks could contact combustibles, with the Permit Issuing Authority retaining the right to increase that distance when warranted. This assumes an area where there is no potential for existence of flammable vapors/gases or materials. Unless there are special topography, flora, weather, circumstantial/situational issues you should feel OK with such a distance, especially with a full time firewatch (equipped with means to extinguish incipient fire).
Jimmy Fix-it
  • 37,916
  • 35
  • 62
