We had a basement flood, and consequently had to rip out the vinyl floor tiles in our basement. The tiles were not asbestos (we had them tested).
But after the tiles came up we discovered that they had been secured with black mastic. The adhesive did test positive for asbestos, 4-5%. So now we need to figure out the safest way to proceed with getting new tiles in, in light of that potentially dangerous material.
Contractors we have spoken to think the best approach is to put down new ceramic or porcelain tiles right over the existing adhesive. They said "capping" the mastic in a seal coat or thin layer of concrete wouldn't be a good idea- they'd need to pour rather a lot of concrete for that.
Originally the contractor wanted to grind the floor (which I've read is exactly the wrong thing to do if mastic has asbestos!) When I balked at the grinding, he said he'd instead use a "fortified mortar" to lay the new tile down. I believe he also referred to this as "high polymer" mortar.
My question: can you lay down ceramic/porcelain tile over existing mastic without grinding the floor? Will it adhere suffiiently? Is there a better/safer approach?
user25271
7 Answers7
I know this is an old question but you would us a modified thinset and tile. NO NO NO you do not use mastic for a basement floor. Next time it flood you will have tile/asbestos coming up. If this option wasn't discussed with you then you had the wrong contractors.
DMoore
  • 50,637
  • 93
  • 208
I just laid tiles over a relatively smooth black glue or mastic covered floor that previously had vinyl tiles. I just swept and mopped the glue and laid the tiles. The black glue doesn’t seem to be going anywhere so I'm sure it'll be fine.
Glorfindel
  • 1,187
Keith
You have two options, you can encapsulate the mastic using a certified product like Perfect Primer to seal in the black mastic then you can tile over it without issues. It is the only primer that works for this purpose, do not try KILZ or some other product.
Better yet, call a licensed asbestos removal company, they can remove the mastic down to the concrete safely without exposing your family to asbestos using solvents designed for this purpose.
Lastly, never attempt to remove asbestos contaminated materials yourself unless you have the proper equipment and training, you cannot see the cancer causing microscopic particles with the naked eye that so don't try it. This isn't drywall or concrete were talking about, it is much more dangerous than drywall dust or concrete dust. Word to the wise, if your tiles had asbestos contaminated mastic your drywall is likely to have asbestos in it as well. It was very common for multiple building product to have asbestos in it.
There is no safe exposure level to asbestos.
z man
An electric tile chipper with a 8-12" sharp blade can be rented cheaply to do the job. Dust level is low but Work with masks and forced window exhaust. It's like a cross between a jack hammer and a sideburn shaver and easy to use . 1 hr to separate from concrete . 1hr to haul out. 1hr to rental place and back. for 500 sq ft.
If it is smooth enough, extra tile adhesive will work too to even out the bumps.
user25261
  • 71
I'm not experienced enough with tile to answer the question directly but have you considered other floor coverings? They make engineered wood that is rated for below grade that will float above the old mastic. As long as the mastic is generally smooth (no ridges between the old tiles) it will go down just fine.
Cost is about the same but if you have a table saw and a miter saw you can do the install yourself. Laying a floating wood floor doesn't take the same skill level as tile does.
diceless
  • 4,446
Call up one of the suppliers of polymer-modified thinset, and see what they say. They are the ones who can tell you whether it works or not.
Eric Gunnerson
  • 2,977
I used an encapsulating asbestos product that I rolled/painted on the floor. I also used this I the bathroom where I laid new tile. It seems to have work well. I haven’t had any problems.
Lorri
