I have a shower that I totally gutted out. I plan to implement a regular shower head and another rain shower head. I already have the majority of the work done and have only one thing left: to run a piece of pipe to the attic, then stick it out back to the shower (around 3-4 feet through the attic).
I have a couple ideas, but not sure which to pursue:
  • To build a box in the attic (ceiling drywall, plus add a piece of plywood on top of the joists in the attic to create an air tight space for the pipe) and cover with insulation
  • add some heating element round the pipe
  • just leave it as is but make sure that the pipe is sloped. This will allow the water to get out of the pipe when there is no pressure (my distribution valve will leak it through the on-the-wall shower).
What is the best way of doing this?
  • 20,909
  • 95
  • 135
Andrew
  • 257
5 Answers5
where is the home? he most important question: Does it freeze in your attic? Even if it freezes - if the pipe is beneath ample insulation it is ok - Unless you are on an extended vacation - in which case must leave the heat on low enough to make sure the house envelope does not drop below freezing.
The insulation above it will be enough because the pipe isn’t under pressure. Just make sure the 90° from the wall to ceiling is higher then the 90° from the ceiling to rain head. This way, when you shut the water it will drain to the rain head and empty the pipe out. Put a few bats above it and you’ll be more then okay
Not sure if this is the right answer, but this is what I did:
  1. removed a piece of drywall from the ceiling and cleaned all the insulation that fell down
  2. built a small plywood box in the attic above the ceiling (only covering the top and sides, with access from below); insulated the seams with silicone
  3. ran the pipe through the plywood box
  4. re-drywalled the ceiling
  5. added insulation in the attic on top of the box that was built
took 1 day to complete
Andrew
  • 257
If I understand your question correctly, you are running a pipe from the in-wall mixing valve into the attic space to supply a rain shower head.
This means that the water in this pipe will never be under pressure.
Make the pipe accessible and protected, insulate around it. This should be more than sufficient.
Matthew
  • 10,823
  • 64
  • 109
Is it a tub/shower combo? If it's totally gutted, what about adding a tub spout with a diverter valve? The vertical column of water to your shower will drain after every use. As long as all the pipes in the attic are pitched, you should be fine.
  • 20,909
  • 95
  • 135
Mike
