I need to reset the pavers for this patio and I have the feeling that, by its look I have to redo the entire patio since the filler that is visible in this picture seems to have reached the end of its life cycle.
Here is a still intact area enter image description here ANd here is one of the many areas where the filler is gone enter image description here
feetwet
  • 2,707
  • 35
  • 52
MiniMe
  • 3,707
  • 107
  • 178
If your brick is level, and moves water away from your house, I wouldn't replace any of it. It takes a lot of time and expertise to get it to set just right, and probably isn't worth the trouble.
If you are really bent on making it look uniform, take a paint scraper, something simple you can get from your local hardware store like this. The pointed end is great for clearing debris between bricks and the like. Use the scraper to clean out as much of the dirt and junk from between the bricks. You can then use a standard leveling sand (which you can also get from your local hardware store), and sweep it into the cracks.
Normally, the purpose of the sand is to fill in the cracks between the bricks to keep them from moving. However, if you get a sand which is lighter in color, then it would probably match well.
John Smith
  • 826
You should be able to pop those pavers out easily. If you are having a tough time getting them out, then you can try starting from an edge and working your way inward.
Here is another question that has a good answer: What should the ratio of crushed rock and sand for a paver patio be?
Jason Hutchinson
  • 3,532
