I have a no-longer-in-use brick chimney running from basement to attic (roof was closed over it), left over from earlier heating systems. The space alongside it is being used for plumbing and electrical, so it would probably be a pain to actually recover those few square feet... but it has me wondering:
How would one extract a brick chimney embedded in the middle of a house? Open up one of the adjacent walls and attack it with rotary hammer? And would the years of combustion residue -- gas and oil most recently, but I suspect there were one or more woodstoves originally -- be a significant health hazard, or just a mess?
(If I don't extract it, I'll probably want to cap it off to make sure it isn't breaking my air-sealing. Thoughts on an easy/cheap way to do that also welcome.)
keshlam
  • 33,603
  • 56
  • 110
We removed an old brick chimney to install a modern (well, 1970's modern - stainless steel is more common these days in your better chimneys) block and tile chimney by simply hammering and removing bricks. If you do it top down it's "apparently more tedious" but actually less time overall than anything involving "knocking it down" and then clearing up the mess, when it's inside an occupied, normally clean house. A wide mason's chisel may help. Bricks are actually pretty easy to get apart when you learn how, and that won't take long if you pay attention to what works on the first few layers.
Incidentally, if you drop the bricks down the chimney they pile up in short order and become a relative pain to remove. Take it from a former teenager who thought that was a great way to get rid of them until we hit the pile coming up as we were tearing down.
Just wanted to make sure this was recorded: Be careful to look at what else the chimney may be supporting, In my 1880's house, the base of the chimney used to help support the ground floor's main beam; that eventually faled which is why the beam now has columns under it (and why the dining room, and the bedroom above it, have tilted floors). It is possible that the corresponding beams for the second floor or the attic floor are still resting on the chimney; if so, I'd have to bring in someone to advise on whether that support is needed and how else we could achieve it.
keshlam
  • 33,603
  • 56
  • 110
Bricks and mortar...
Anecdotally, I removed an embedded brick chimney from a 1900's era house. It was (floating above for a stove) resting on a 2x4 frame, supported by two 2x4's at a 45. Amazingly even once removed, someone had to go in the attic and pound on it a little. KABOOM! -and then we took a nice long lunch. We first removed what we could from the attic. -by throwing it down the chimney.
If you're removing it to regain wall space, then the old soffit is in the way anyway; open up the drywall/knock the wall down. The respirator (not a dust mask) you should be wearing for demolition will protect you from all that stuff.
Surgically?
  • Remove as much off the top as you can get to.
  • Notch out an area of the lower section to install temporary bracing.
  • Remove the lower section.
  • Remove the bracing.
  • Kaboom (protect the floor appropriately).
  • Take lunch.
Mazura
  • 13,598
  • 58
