I aim to fit a (fairly heavy) kitchen wall cabinet to a plasterboard wall. Behind the plasterboard there does not appear to be any studs. So I guess the plasterboard (what I would call drywall - plasterboard with no studs) has been glued to the brick exterior wall which lies behind the plasterboard. The cabinet once fitted will be laden with lots of heavy pans etc.
Can the plasterboard be drilled through and into the brick wall behind it? What type of plugs / fastening would be recommended?
suspectus
  • 113
I'd recommend these lag shields
enter image description here but the info in this link can help you decide. You could probably go with simple lead sleeves but without knowing the condition of your brick or the exact weight of the load you'll be supporting lag shields are a safer bet. As far as going through the plasterboard goes, it's not any different than attaching something to studs through drywall, you just need to make sure you're drywall is compressed between the cabinet back and the supporting wall. If there is a void between the two it will collapse when you tighten down your anchors or worse, when you put weight in your cabinet.
