I know there are units made which are supposed to be sized for use in a residential kitchen, as a more efficient replacement for the usual vent hood (bring air in to replace air blown out, but transfer heat between the two so you don't lose as much heating/cooling as you would with a normal just-blow-outward setup). I like the idea, but they ARE more expensive (of course; two fans and the heat exchanger and the internal ductwork to feed it) and I'm not sure how much maintenance they need... especially since in a kitchen setting you're going to get airborne grease and so on which may make keeping it working efficiently difficult.
So: If you've installed one of these, how did it work out and would you do it again?
keshlam
  • 33,603
  • 56
  • 110
Due to the grease and other unwanted fumes being exhausted this is not a good idea for a range hood in the kitchen. You would be surprised at how easily grease builds.
Russell
  • 66
