I recently moved into a high rise apartment and need to hang some cabinets. The cabinets themselves weight about 20lbs and I'm thinking the stuff stored inside them will be around 40lbs.
I know I need to mount these into the studs which I've been told should be metal since it is a high rise, but I'm not sure how to double check this?
I went to Home Depot and bought a pack of 2" metal stud screws, which is what I was recommended by the person working there. I just want to double check that this is ok and will actually support the amount of weight (~60lbs). I know that I need to drill a pilot hole before putting the screw through but is there anything else I should be aware of when hanging these shelves? In terms of metal studs, as I have never mounted anything using metal studs.
This is the cabinet I am trying to mount, I have a single like this one and also a double which is two of these attached to each other and are all mounted using a suspension rail.
Tudor
  • 121
From my research, it seems like snap toggles are highly recommended, and for your situation with metal studs, I think they would work since the approximate weight you are estimating is 60 lbs. Snaptoggles (aka toggle straps aka toggler bolts) claim to hold over 200 lbs in 1/2" drywall.
I have yet to use them myself, so it would be cool if another member here can comment on them.
How did your project work out? Did you mount your cabinets? I am looking for similar info as I also just moved into a high-rise building and my apartment wall has metal studs, so I researching solutions to mount my tv.
Jack
  • 38,117
  • 66
Dragon2020
  • 57
