Which one is preferable if you have a straight line 2 feet deep trench in mostly clay soil?
I'll put either one in a sock with gravel.
There are some roots around the trench so I thought the solid pipe would be sturdier.
Any comments on this would be appreciated.
Edit: I need more comments please.
ChrisF
  • 16,973
  • 74
Peter Q
  • 2,223
  • 43
5 Answers5
Tim Carter at AskTheBuilder.com has a lot of articles on French/Trench drains. He likes solid pipe and I agree. You are correct in that the holes point DOWN. Here's why - the water won't magicially find the holes if they are pointed up, but if they are down, the water can fill the trench and then flow into the pipe. Put a cleanout on the upper end if you can, if you don't want it sticking out of the ground, then come up with a 45 elbow and bury the cap right below the ground. I would NOT put a sock on the pipe. That will just clog. If dirt gets into the pipe, most will flow out because its rigid, and hopefully you can put a cleanout on it, or you can run a snake in from the outlet. I would put some straw or landscape fabric right under the top soil. Use 3/4 gravel as filler, not smaller. Read Tim's articles if you get a chance.
BrianK
  • 5,475
  • 38
Use the solid pipe -- two feet of clay soil will be very heavy, especially when wet, and I can see the flexible pipe deforming as you fill in the trench, potentially causing a blockage in your nice new French drain.
  • 20,909
  • 95
  • 135
The holes point down, below the pipe is a 2-3 in layer of gravel that the pipe sits on. The pipe needs to drop 1/8 inch per foot of distance, if I'm not mistaken. 80 feet distance equals 10 inch drop from the start of drain to finish (where it drains to). I'm unsure which pipe is better to use overall but I would assume solid PVC (with holes pointed down) would work better if a lot of material is piled on. (Deep trench, heavy soil). Picture the trench without the pipe, just a thin layer of gravel in a trench sloping down gradually. The water would flow just fine through the gravel and down the trench until it filled past gravel and eroded the dirt into the trench. If there is very little water the pipe doesn't fill and just flows through gravel under pipe to the low end. When there is a lot of water it fills the thin gravel layer and continues upward into the holes of the pipe which gives the water an easy path to follow in large amounts without eroding dirt on side of trench. The sides of the trench wall and all sides of pipe have gravel around them to let water go through the gravel from the grass, dirt, sidewalk etc. to enter the pipe. If holes are up or on sides of pipe then the water has to fill the trench until it hits a hole to enter the pipe and drain away to low end. Holes down keeps the water from having to fill so high before the pipe can do its job. Socks on pipe and fabric in trench containing the gravel keep dirt and other small particles from mixing with gravel or entering pipe decreasing the likelihood of clogging or otherwise obstructing water flow. It will make all your hard work last longer without issues and cleaning out.
Bul
Has ANYONE actually set-up various french drain configurations behind clear plexiglass (cut away-like an ant farm display) to see (for real) how it performs?
In my 'minds eye', the possibility of collapse (despite the corrugations (I've seen crunched perforated pipe at the store!)) and the idea of standing water within the corrugations makes the flex pipe less of a candidate behind a retaining wall 4ft or higher in a clay environment.
Solid perforated PVC: Hmmm...Holes up lets water in directly above the pipe and that's it. Holes down hopes water will find a path of least resistance and voluntarily enter the pipe on a journey to a desired outlet away from the retaining wall to alleviate hydrostatic pressure.
It seems best to combine the best attributes of both systems to use solid perforated pipe with holes drilled/punched all around to ENSURE water finds its way inside to travel down stream.
Regarding the water seeping out...yes, water will seep out under low or zero precipitation conditions where water behind a retaining wall will not be an issue. However, during moderate to heavy precipitation, water will be taking the path of least resistance, once it finds its way into the pipe, and since water is draining through the backfill stone everywhere, flow into and through the pipe downstream until precipitation subsides. Keep in mind, appropriate airflow needs to exist for water to flow. Keep the outlet above ground/water level taking into consideration for water pooling at the outlet.
None of this is proven...just my minds eye perspective.
Sorry, I have to disagree to solid pipe. Regardless of what type of soils surround the trench, the back fill for the drain must be pea stone or gravel. If you use solid pipe, how is the water going to enter the pipe to be drained? Solid pipe would be fine for a floor drain etc, but by definition, a French drain is a continuous porous downhill drain. Use the flex pipe, point the holes up and cover it with landscape cloth, and backfill with a good draining material.
shirlock homes
  • 58,628
  • 87
  • 168
