Disclaimer: No, I can't buy ready made surface leveler, because in Brazil this doesn't exist.
I need to use a resurface a dry pack levelling that my previous contractor made a lousy job (porous surface here and there and a few cracks, but it seem well adhered). He is not answering my calls and I'm not calling anyone else to fix something this small.
Everytime I mixed sand and cement I always got a headache on getting the right mix or the right type of sand (in Brazil there are at least 4 different types of sand: coarse, medium, fine, and washed, most from river beds).
What would be a good recipe for a resurfacer, also, I should use bonding agent, right?
Luiz Borges
  • 2,345
  • 69
  • 83
The latex paint should not be more than 20%. So mix the latex and water at 2 to 10 and use it to mix 2 parts white cement and 5 parts fine sand.
Adding ajax dish liquid (do not use dawn or ivory) to the mix alows and easier spread and a creamier texture like peanut butter.
Roughen all areas to be resurfaced, remove any loose or unstable material. Dry mix 5 parts fine sand to 1 part portland cement. Moisten entire area to be resurfaced. Add small amounts of water, a little bit at a time, and thoroughly mix until entire batch is damp. For initial dry-pack, proper mix should hold as a clump if you squeeze together in your hand, but easily come apart if you break it up. For your resurfacing purpose, it could be a bit wetter but not liquidy. Spread out and pack firmly into area in question with a wood float, use the wood float to feather the edges of the repair into existing surface. Use a spray bottle to moisten as needed while you float it out. Screed or float out as level as you need it to be but the surface does not have to be super smooth.
Apply water-proofing membrane, then apply additional treatments (float regular cement on top of membrane then install tile?). Drypack is most often used to establish initial slope for the surface, not for applying final finish treatment to.
Jimmy Fix-it
  • 37,916
  • 35
  • 62
-2
The following recipe might work better (but can take days to dry).
1 part latex paint, 1 part cement,
1 part water,
4 parts fine sand.
Latex paint adds polymers to the cement which will reduce shrinkage and help maintain it's originial form.
Source: http://www.ehow.com/how_4516234_mix-latex-paint-concrete.html
Ben Welborn
  • 6,292
  • 49
Paul
