I have a new Herman Miller Mirra chair. I love it and do not want to return it, but it makes irritatingly loud creaking noises when I shift my weight or recline.
The source of the noise is the loose plastic shell that covers the recline assembly and is gently secured with S-clips. Any force against this hollow shell makes it deform slightly and produces the sound. Attempting to damp the noise by padding the loose areas of the shell to resist deforming does not help.
mstrange
  • 161
After some experimentation, I found that the underlying problem was from overtightening the bolts that connect the chair back to the seat assembly. Doing so puts excess pressure on the plastic shell and causes the creaking sounds. By loosening the bolts and refastening them without heavy torque, the problem is resolved and the chair reclines and moves silently.
mstrange
  • 161
