I'd like to vent my range hood out through an exterior brick wall. How would I go about making a 6 inch hole for the vent?
  • I'd guess I'd use a masonry chisel to chip out the mortar and then pull out a couple bricks on the interior and exterior layers of the wall. Is this the best tool/approach to use?
  • Do I need to be concerned about the load of the bricks above the hole?
  • How would I make the hole round rather than square?
  • Any other considerations?
jlpp
  • 1,974
5 Answers5
It is entirely possible to construct a 6 inch hole in brickwork. The problem with a round hole rather than a square hole is where the hole cuts across joints in the masonry leaving small triangular pieces of masonry over the hole. These tend to be fairly week so are best avoided. You would therefore have to position the circular hole carefully so that is best placed not to leave small or week sections of masonry. As mentioned in other answers to get a good hole, a diamond or similar circular hole saw is the best way but at this diameter you made need a large pillar drill rig to use the hole saw and this may need to be bolted to the wall prior to making the cut.
If you can fill it a square hole then may be better. Given the diameter of the hole you are suggesting you shouldn't have any structural problems as long as you aren't right next to openings or corners in the wall. The key is to make sure that the hole doesn't leave a whole brick unsupported from below when you make the hole and with a 6" diameter this shouldn't be a problem unless your bricks are very small. The neatest way of doing this is to cut out the edges of your hole with something like a disk cutter and then use an impact hammer to chisel out the brickwork in the centre. This should leave a very neat cut.
Ian Turner
  • 1,062
If you only have to cut through one course of brick, the easiest way would be to go to your local rental center, rent a powerful/professional rotary/impact drill. Some may come with hole saws, but you can buy one at a HI store for around $30. This will make a clean hole for your vent.
shirlock homes
  • 58,628
  • 87
  • 168
I think 6" masonry hole saw bit and a strong drill would be the ticket--but those bits are expensive.
richardtallent
  • 1,938
A standard SDS drill would not be strong enough. I seriously doubt there is any such thing as a 6" SDS bit. This is -at minimum- a job for an SDS-max or spline drill. Those bits are several hundreds of dollars; this is an inexpensive one
I have also seen hole saws designs for a 7.5" or 9" grinder...
I just made exactly this type of hole: 6⅜" through 13" of solid brick wall. I used a Milwaukee M18 fuel drill and a Milwaukee recessed light hole saw with the grit vs. teeth. I used a 12V Milwaukee palm nailer with a ⅜ inch drill bit as a mini jack hammer for busting out the brick pieces and a simple chisel and hammer. It took about 2 hours.
You can get concrete boring bits for about $90 in 6" size but if your brick is soft enough the ceiling can saw will work fine.
  • 20,909
  • 95
  • 135
