I have random sewer odors coming from my tub and shower drains. They are separate in my bathroom. I have had plumbers come and clean the drain, but that is not fixing the problem.
helen
You have sewer gas. Water in your plumbing traps is supposed to prevent that. There's some problem that is resulting in not having a water seal in your traps for these items (they may share one trap if it happens to both at the same time.)
If you pour water down the affected fixture (slowly) does the odor stop shortly thereafter? Or, if you carefully do this after each use, does the problem not occur (since it can be hard to tell when an odor stops coming in, if it's lingering around the bathroom.)
If so, you may have a venting problem, with the traps being sucked dry when lots of water goes down and creates a siphon (what venting is supposed to prevent.)
How old is the house and/or the bathroom? Another common possibility for an older house is that an old drum trap has failed, and is not functioning as a trap at all anymore. "Pouring water slowly down the drain" would have no effect in this case.
It's surprising that plumbers would not have mentioned or investigated these possible causes, unless they were only asked to clean the drains, rather than to identify and solve the smell problem.
Is that bathroom used much? Our 3rd bathroom tub never gets used. As a result (we surmise), the water in the drain evaporates, allowing sewer gas to find its way into the house. We just run the tub for a minute every week or two to fill the drain. Haven't had the problem since.
InbetweenWeekends
  • 600
I had the same problem after I had my bathroom remodeled. I just pour some vinegar down the drain and it goes away. I'm not sure what caused it but the vinegar solves the problem for now. I had to do it a few months ago.
