I have a concrete driveway that leads to the garage, with a very slight slope towards the garage.
When it really rains hard, the water comes down into the garage.
I don't want a very high barrier, just about an inch I guess would do.
What is the best way to do this please?
I will explore both good answers but cannot rebuild the driveway whilst I do have an appreciation for water and what it can do. This little wall will actually divert water from the garage wall to a channel that runs away from the property.
  • 20,909
  • 95
  • 135
ozstar
7 Answers7
Glue-down garage door seal (sometimes called threshold seal) sounds like what you want. A rubber bump.
I had a similar problem, I made a 1" high, 3" wide concrete bump using some angled wood strips to hold it until set. The two strips were joined using small cross-bracing pieces of wood screwed from above. The strips were something like a 6 or 7 foot length of 2x1" wood at about 45 degrees to the ground. I made the concrete bump in sections that length. I think I used a sack of ready-mixed concrete to which I just added water.
It worked well because I have a surface drain one foot in front of the bump and I just needed to hold the water a little from rushing past the drain into my garage. It was only ever a problem when there was sudden heavy rain.
Whether this will work for you depends on your exact situation.
RedGrittyBrick
  • 24,700
  • 50
  • 94
I wonder if an old car tire could be cut into strips about 2" wide with a sawsall and dispose of the sidewall completely. This would form 2" rings, you could probably get at least 3 per tire. (Depending on the width of the tire). Then cut the rings open and lay out the 2" wide strips on the desired area and screw them into the existing pavement with concrete screws from local Ace hardware. I imagine you would yield 4' long strips, (depending on the size of the tire of course). So, probably 10 - 12 ft. of strip per tire. If it works it would be a great ECO solution. Good Luck!
Micky
Do what I did, speed bump across the opening 1",2" or 3" avil.
-2
I was looking up how to stop floods then voila!! It came to me floodwater safety barriers!!!!!
-3
My advice is never, and I mean NEVER fool around with water. Don’t just put some small barrier, because then water will stop at the barrier and from there God knows where will it go from there. You can cause much bigger damage than it is now. I know that you not going to like what I'm about to say but you really should rebuild entire driveway properly.
python starter
  • 733
