I have a light fixture that lists the maximum bulb wattage as 60W. Right now, I have a standard incandescent bulb in place. Since there is only one light in the room, a single bulb is not bright enough. Can I safely switch to CFLs or LEDs with a greater Lumen output than the standard 60 incandescent as long as I don't go over the 60W draw?
Asked
Active
Viewed 472 times
Yes. The more efficient bulb will also produce less heat, so it should be fine. The only concern is that if there is a dimmer you need a dimmable bulb, and if there is a touch switch or other circuit that was powering itself via a trickle current thru the bulb that may not work -- but neither it nor the bulb will be harmed by the experiment, so go for it.
keshlam
- 33,603
- 5
- 56
- 110
