12
I think most people would agree that sound proofing a bathroom is a swell idea. Since bathrooms are special rooms (high humidity), what are some tips and techniques you can use to sound proof one without running into water/mold problems down the line?
I am asking in the context of a bathroom in the process of being remodeled. This allows major "design" changes but probably not significant structural changes.
Aarthi
  • 1,143
Joe Phillips
  • 2,286
  • 46
  • 61
Add a second layer of drywall with Green Glue for sound isolation; not shilling, just heard very good things about it and plan to use it to soundproof a den.
SqlACID
  • 1,272
I would use a sound proofing insulation in the walls, then instead of using normal drywall, use a moisture resistant or mold resistant type. Thicker drywall will also help with sound deadening.
At last resort, put in a super loud ceiling fan that turns on with the light, that way even if it'll cover up the sound of you peeing. :)
Dilbert789
  • 1,013
