I bought new sheets for my son, and I put the Target plastic bag, with heavy sheets in it, on top of the washer for the sheets to be washed. This morning I picked up the bag, and I've got red bullseyes on my white washing machine! How the print won't come off this surface easily is amazing, but per my Google search, this isn't out of the ordinary when you combine walls and furniture (and apparently appliances) with printed plastic bags. Who knows what causes it in each case, though. I checked the off-white carpet where this bag sat prior to being placed on the washer, and it's clean. I'm guessing I had liquid residue on my washing machine (probably from spraying stain remover on 1/4 of the clothes that get washed) that coaxed the print off the bag.
Windex did not work. Magic Eraser did not work. Baking soda did not work. Goo Gone did not work. Multi-purpose cleaner (generic 409) did not work.
I am left with light pink bullseyes :(
I also have Murphy's Oil Soap (which I have as a kind-of-solution for getting dry erase marker out of clothes, long story, only use on white fabric!) but have not tried it because I only have a few drops left. If I need to buy more, so be it. Does anyone have any thoughts on it?
Before I turn my laundry room into a deli, does anyone know what the alleged magic of mayo is? I see a lot of people suggesting using it both in this forum and elsewhere.
Thank you!
Rebecca
  • 111
7 Answers7
I had a similar problem about two years ago and a guy friend brought over something called "Rubbing Compound" or sometimes called "buffing compound" used to polish away scuffs and scratches on cars. It worked, but wasn't a bag from Target that left the imprint so not sure if it's the same coloring chemicals. From what I gather, if rubbing compound doesn't work, then it means the color is absorbed in to the paint and may be more difficult to remove.
I experienced a similar problem, nothing was taking the colour off - magic eraser, soft scrub, wd40. But nail polish remover (with acetone) did the trick! There's a faint colour spot still but only to me because I know it's there.
BMitch
  • 43,263
  • 98
  • 204
Karen
I don't see bleach on your list of things? Red has a real problem with bleach. If that doesn't work, you may try WD-40 or even carburetor cleaner. Just use either with a lot of fresh air available. Soft Scrub works pretty well for this kind of thing, too, but it uses bleach, so may not be any better than using straight bleach.
Pᴀᴜʟsᴛᴇʀ2
  • 576
try liquid dish soap. squirt onto stain and let sit for a few hours. this will take the old style blue ink (that used to be on packages of meat when I was a kid) out of your sink or formica countertops. The stain rises to the top of the soap puddle. Then you can repeat. no scrubbing needed just time.
karen
Try sprinkling baking soda, then cover with white paper towel, then pour a small amount of hydrogen peroxide to wet the paper towel. I do this to bleach my porcelain sink. I let it sit that way overnight. It might work.
Mary
I don't know who needs to hear about this out there, but olive oil and baking soda will get plastic bag ink stains off! Make a thick paste and just let it sit.
Just adding my results for a plastic (acrylic) bath that had blue ink from ice bags.
Rubbing alcohol removed the ink from the bath.
Acetone nail polish remover cleaned the drain plastic.
Goodluck!! before and after picture
Nanet
