So I have a bunch of partially used latex paint in 1 gallon and 5 gallon buckets. How could one store and keep the paint viable for years to come? Could I just vigorously shake the buckets once a year or so?
For now I store the paint in my basement.
I don't know where I found this method but my paint has lasted about 3 years so far without drying: Place aluminum foil over the can before securing the lid. Of course you need to make sure the lid sealing surface is clean. Also, a rubber hammer to fully seal lid helps. I really like the water bottle idea. Gonna try it next.
I use plastic containers and the smallest size to store the amount of paint I have, cutting down on the air stored with the paint. I like the protein powder and kids vitamin containers. Those are 1/2 gallon and 1 pint sizes. I have found that if you think the paint with any tap water, don't even bother; stuff will grow in it.
I use the Arizona plastic bottles, they are strong & have a twist off cap on top. Simply use a large funnel to transfer the paint into it.
The problem with trying to keep latex paint fresh isn't with the paint itself, but with the paint container. From wait I've noticed is the metal containers because of the water mixed in with the paint, will eventually oxidize the metal. Usually the rusting continues until the can is compromised and the paint solidifies. The best way to preserve a gallon of paint would be to add a plastic or rubber membrane so as to increase the seal between the can and lid. A garbage bag would do. Remove all paint (dried or not) from the lid well (groove). Place the new seal on the can followed by the lid. Gently tap the lid until completely seated. Invert the can to help increase the seal.
