Folks, I need to remove an old kerosene storage tank (for central heating) from my in-laws back garden. The tank is moulded plastic, and has a 1,000 litre capacity.
The access point it was originally brought through is gone.
The tank has been empty for 10 years or so, the easiest way to remove it is to cut it up, and the easiest way to cut it up would be with an Angle Grinder.
There is a small amount of liquid in the tank, which is (mostly) water, I'm assured the tank was emptied by professionals.
Obviously I'm worried that there may be residual fuel/fumes that the Angle Grinder could ignite.
Is there any way to quantify the ignition risk, or some anti-philostogen agent (i.e. fire retardant) I can add to the tank that will completely negate the ignition risk?
BMitch
  • 43,263
  • 98
  • 204
Binary Worrier
  • 289
8 Answers8
Kerosene is not terribly flammable, so it probably is not a problem anyway. I'd pick a windy day, or even simpler, maybe have a fan blowing across where you are working, to keep any fumes away from the motor.
I'd also use a reciprocating saw, not an angle grinder, at least if I had the choice. Even if you have a carbide blade for the grinder, a reciprocating saw may still cut as fast or faster than a grinder, and it will generate less heat when cutting a plastic tank body.
If you are still worried, I'll bet that a good sharp (hand powered) pruning saw, the type that cuts on the pull stroke, will cut up a plastic tank at least as easily as would an angle grinder.
You shouldn't ever use angle grinders on plastic - when cut at such high speeds plastic will melt and evaporate and could start a fire even without kerosene. Your best bet is a plain old hand saw - it will cut plastic rather fast.
sharptooth
  • 9,717
  • 65
  • 89
A reciprocating saw, aka sawzall, will do well with plastic. If you don't already own one, you should consider it, or find a friend, or rent one.
BMitch
  • 43,263
  • 98
  • 204
It's probably not a problem, but to be safer you can dump in a bunch of dry ice and let the CO2 displace the air. This will work best if the only opening to the tank is at the very top, since the CO2 is heavier than air. See here for a website promoting this idea.
Lev Bishop
  • 372
I would take a drill and put a few holes in the tank, first on the top to let fumes escape and then the bottom to allow any liquid to drain out. A would expect for a drill to have a lower spark risk. Wait a bit after making the holes and then come back and cut it up however you want.
Joel Coehoorn
  • 307
Just to let you all know. I am a Oftec registered Technician and kerosene is the safest form of fuel to work with and is very unlikely to cause a fire. However, precautions must be made to prevent the likely hood of a fire in close proximity by adhering to the regulations set out by Oftec. Kerosene will only ignite if it is atomised or vaporised.
If you cut a plastic tank with a angle grinder, this is not going to cause any problems because no sparks are produced. Even if there were a few, it wouldn't ignite what little fuel was in bottom of tank. Best way is to cut top of first and then in sections
maples
  • 388
If you have access to a welding supply - use C02 or Nitrogen gas and just keep a constant flow of gas into the tank as you work
-2
An interesting selection of hints and replies with most giving details of how to make a simple job into a difficult or involved one. To dispose of an unwanted domestic style plastic kerosene oil tank, first ensure it is empty, buy a nice new (sharp) hand saw from jewsons, cut the tank in half, then quarters and so on until small enough to transport to your local recycling centre. Check first but most will accept ok as plastic. If you are hooked on using power tools then so be it but not necessary to get the job done safely and easily with little chance of accidents. (see best reply from 'sharptooth' dated 7 Jul 2011.
Bob
