Can I remove bluestone pavers embedded in mortar and reuse them? A house with a bluestone foyer is being demolished and I would like to salvage the pavers and reuse them in my new home.
StayOnTarget
  • 5,675
  • 58
  • 102
Bob Z
You can always try. You will need to break some of the grout away so you can see the base where the paver and the mortar meet. Then using a floor chisel (3 inch wide blade cold chisel) set between the paver and the mortar, see if you can pop the paver up. If the paver is not well bonded to the mortar, they will pop up. If they are well bonded, they will just snap when the one side is getting lifted.
diceless
  • 4,446
If you can get power (the place being demolished or a generator) your best bet in just getting them out would be a circular saw with a Diamond Tipped blade or a few Black Fiber blades (they wear down pretty quick but are cheap). Of course, don't cut the Bluestone cut the mortar around them.
Then, you can soak & chisel on them at home. I don't really suggest it since I haven't done it, but if the mortar isn't budging & you've already snapped one or lost corners. If they fit in your freezer I knew some salvagers that swore by it to free brick, marble & tile inlays. Perform at your own risk.
Iggy
  • 10,392
I think it's going to depend on whether they are actually embedded in mortar or just glued down with mortar in-between. I don't see this working. I think they'll break but you'd have to try it with some flat bars to see. Either it's going to work or it isn't. No special trick I can think of to keep them from breaking.
maplemale
  • 1,096
