So I was just watching Holmes on Homes, and they were showing a quick close-up of cutting a 2x4, making two passes, cutting the top half first, then finishing it off:
cut in two passes
I've never seen (or at least noticed) anyone do it this way before, nor can I find any info on it. I usually just cut straight down, or go across the whole board in one pass. Is there some benefit to doing it this way? What's the "proper" way to cut through dimensional lumber?
gregmac
  • 29,300
  • 89
  • 162
I watched the vid on Utube, very interesting. I don't use a slide chop saw for 2X4's (I use a 12" fixed) but that technique looks good to me. I think the reason is that taking two shallow passes is just as fast and doesn't load down the saw as much as a single pass. Since the angle of contact using a slide saw is much different than a fixed I can see why the double pass is effective. Leave it to Mike Holmes to find a better way to do most anything!
shirlock homes
  • 58,628
  • 87
  • 168
One simple answer: tearout. As the blade leaves the wood, if it traveling along the length of the wood it leaves a nicer cut. Score it first then make your main cut
Machavity
  • 26,498
  • 44
  • 100
lon
