I'm trying to figure out the most ideal way to install hydronic radiant heat in my basement over the existing concrete slab. I've looked at several products for heat distribution, like Warmboard, before settling on this: http://radiantengineering.com/tfinu
I'm trying to figure out the ideal way to install it with the minimal loss of height. I was provided a sample of the aluminum fin and its height measured to just under 3/4". In their brochures and pictures, the fins are shown attached downward but I'm thinking it may be better to face them upward. I'm also planning to go with an engineered hardwood floor atop.
My current best guess to the ideal way of doing this is to first start with a 6 mil poly sheet as a vapor barrier. Next, get ~1/2" OSB boards and cut 1/4" dado grooves 8" OC where the fins will be placed and make a floating subfloor out of it. Next, I'd cut the same kind of 1/2" OSB into sections just under 8" in width and place them in between the groves. This should provide enough height for the fins to fit in. Finally, I'll use 1" screws (still figuring out that part) to fasten the fins to the two layers of OSB. I've attached a quick and dirty picture to illustrate what I mean (screws are not to scale).
Thermofin U with subfloor
I'm hoping someone could chime and provide some feedback to this approach. Or am I totally missing something really obvious here? I don't want to lay the PEX down and pour concrete over it because that goes into a whole other topic about thermal mass and heat loss.
Thanks
vlozko
  • 87
From Radiant Engineering, thanks for discussing our ThermoFin U product. The preferred method is to install the plates with the fins down. For a ThermoFin U installation on concrete, you would build a surface to be able to screw the plates into by first putting down a layer of Atlas Rboard®, recommended 1/2", which you should be able to get from your local building supplier. A Google search on Atlas Rboard® will bring up their site and the product info.
On top of the Rboard® you would put down a layer of plywood. The fasteners will hold best if you can use 3/8" plywood. It will work with 1/2" plywood if necessary.
Keep in mind that you want the heat energy to be going into the plywood sleepers and the finish floor, which is why we recommend the Rboard®.
The energy without the layer of insulation will be drawn into the concrete, and the response time would be longer in heating the floor. Heating up the mass of concrete is not necessarily a good thing when you want the entire surface floor to be warmed. The ThermoFin U heat transfer plates are easier to install if the fins are down against the subfloor and plywood sleepers on the fins. See the PDF multipage spec sheet that is linked on the U-fin page of our site. You are making a sandwich of aluminum and plywood to evenly heat the structure and provide a friendly surface for the flooring installation. You can call or email us for more help. We also have routed 180 degree return bends for the PEX tubing when using ThermoFin U.
assuming you are going to put a finished floor over top of all of this, you are going to have to add another layer on top of the radiators to subfloor it. this is going to add another 1/2" or so, 5/8" really. so your total floor height is going to be 1.625" or so, before you put your flooring on. you could easily pour a concrete floor at this thickness if you use use fiber reinforced mpa30 or higher concrete (air entrained or not).
to minimize thickness, you can use foil insulation liner to act as a thermal reflector. just lay it on the old slab prior to pouring the new concrete.
concrete will be cheaper to install than OSB, be more stable and have far higher thermal mass (which will take longer to warm up but will radiate the heat longer so its actually more efficient from a heating/cooling cycle perspective)
however, I tell this fact customers all the time. 1 1.5kw electric space heater costs 15cents to run for an hour. even if you left it running 24 hours a day for 4 months (the typical heating season), it would only cost you $400 to heat that space for that period of time. you will spend 5 times that just to do the work you are talking about, not to mention you will still have to pay to fire the boiler to heat the water to run through the radiant floor.
its usually way more cost effective to add 3.5" foam insulation throughout the whole height of the basement wall. you will almost always save more money conserving the heat you already have then you will trying to put more heat into a space. and it will be more comfortable.
I am in a similar situation and was thinking along the same idea of using OSB. Depending on the part of the country you live, the basement floor slab will usually be a fairly constant 50 to 56 degrees. Factors which could alter this would be half basements or high enough altitudes that you are sitting on permafrost. Another factor is walk out basements. My idea is to put a thin (1/4") reflective insulator over my vapor barrier, then use 7/16" OSB in 2 layers Most engineered plank can go directly over that and will bridge the PEX without a problem. This will end up being about a 1-1/2 loss of ceiling height While it would be nice to be able to do a 1-1/2 layer of concrete with the tubing in the concrete, it is just cost prohibitive in certain areas. In my area, it is $1,500 just to get the concrete truck and pumper to my site. With the concrete on insulating board, and an engineered plank floor on top of that, the ceiling height loss will be closer to 2-1/2". This results in a greater reduction of square foot value of that space for resale purposes - another important consideration. The expert recommended possibly looking at using a portable heater in your space, due to the cost vs in-floor heat. This might be a good solution. Made me recall a house we had with a partial garden basement. I ripped thin strips of plastic 1/4" thick, adhered them to the concrete floor, then over the top with a vapor barrier and 3/4 OSB, then carpet over that. The house was in Colorado at 5,800 ft altitude. I would occasionally use a space heater, but it was generally very comfortable. Another solution might be to forgo the in-floor heat, but still put a vapor barrier and thin insulation with the 1/2" OSB with engineered floor on top, then install hot water baseboard heat around the perimeter.
Kevin
We used Crete heat panels sized for 1/2 pecks tubbing it comes with the lock pucks do not have to staple any thing to the floor we always put sheets of foil face insulation under the Crete panels we go around the space along each outside wall we use foil face straps cut at right height to match new floor line along the walls after the pecks is installed we have company spread the self level jep Crete mix it is very liquid it must be dry and set up surface color will be almost white white before any flooring we did this in a building on a slab when done our total height increase was 2 and 5/8s before floor covering Home Depot has a flooring that has a ceramic cour so it transfers heat very well the building was 38 by 56 steel finished inside. I had a contractor put pecks down set the different heat areas with nessaty manifolds and a Propane boiler set the temp in the fall warm up the floor great heat and very cost efficient. Mini splits for air conditioning system works great
Rick
