I have a bungalow house built in the early 1930's. It is in remarkable condition and has been well maintained. In the last few weeks a few cracks have shown up in the ceiling. There is an upstairs but I see no water damage and the area above the cracks is a crawlspace with nothing really in it. My wife has suggested tape, spackle, and paint for the repair. The cracks are ~1/16" wide now but run most of the length of the ceiling from the back wall towards the front (about 13' of a 16' wide room).
Is the tape, spackle, paint method effective? I do not want to spend $500 on a contracter for something i can do myself in 20 min of effort, but I also do not want to throw up a quick fix if it is something that really needs a greater fix. Any suggestions?
Aarthi
  • 1,143
Chad
  • 173
If the cracks have appeared recently and are still growing (in length and number) then this potentially indicates something serious.
Before you attempt any repair - which is perfectly possible using the method you outline - get someone in to have a look so see what might be causing them.
Have you put anything up in the crawlspace recently, or taken anything out?
Have you had an unusually wet or dry spell? This will change the ground conditions possibly causing the house to move which in turn could cause the cracking.
ChrisF
  • 16,973
  • 74
