I arrived home today from running some errands to find that the carbon monoxide alarm in my garage was going off. The display was reading 55 ppm CO (which I gather is a non-lethal but nevertheless high reading).
The garage is detached from the house and has no heat. There are several pieces of gas-powered lawn equipment stored there but nothing has been running. I was gone from the house for several hours so I assume any exhaust from the car briefly running in the garage had dissipated. (When I left the house I just started the car and drove out... no remote start or idling in the garage.)
Does anyone have any idea what the cause of carbon monoxide might be? The CO alarm is less than a year old. Is it defective?
Hank
  • 14,213
  • 46
  • 48
The answer is fairly obvious to me. For one thing, 55 parts per million isn't "high".
When cold engines first start, they run rich," Greiner said. The catalytic converter is cold and not converting deadly carbon monoxide (CO) to carbon dioxide (CO2). Concentrations in the exhaust can be more than 80,000 parts per million. Concentrations so large fill the garage with carbon monoxide in a very short time even with the door open. ...after only two minutes of warm-up in the opened garage, carbon monoxide concentrations rose to a lethal 575 parts per million
https://www.extension.iastate.edu/pages/communications/CO/co_car.html
I actually just had a very similar situation of the CO monitor in the garage. No recent car usage, and the CO sensor suddenly went off at ~50ppm.
EMT and gas company came to check, and ultimately the source was a power transformer and a charging battery. All other likely sources (furnace, water heater, drier, oven, gas lines, etc.) were checked and conclusively shown to not be the source(s).
For reasons that I don't completely comprehend, the electronic devices either offgas CO or Hydrogen gas (which is then misread by the CO detector). Both of the charging battery and power transformer were a very slow sources, but built up in the garage over time until the alarm set off at ~50ppm. Unplugging the power transformer and the battery immediately resolved the problem. I was told by the gas company that they see this infrequently but not rarely: charging batteries are an unlikely but valid reason to have CO detectors go off.
I would not recommend determining with a commercial/home use CO detector alone if that is your root cause. I would recommend relying on a professional or an industrial CO detector to determine if that is your root cause.
isherwood's answer is good. Check out this information about why you shouldn't put a CO detector in your garage. The link below has lots of other useful information, as well.
Can I place a CO detector or alarm in the garage to warm me of excessive CO? No. Residential detectors are not designed or approved to operate in garage conditions. Temperatures and humidity variations are too large, and the high start-up amounts of carbon monoxide can easily damage or destroy the sensing cell. CO detectors should never be placed or used in the garage."
http://www.abe.iastate.edu/extension-and-outreach/carbon-monoxide-poisoning-garages-aen-207/
thatguy
  • 107
