Are there any gotchas to garage door lubrication?
I have found the Prime Flo product on Home Depot's website.
Can I lubricate the large spring at the top of the garage door? What about the garage rails? What about the rail from the garage opener that makes it all work?
Aarthi
  • 1,143
The rail from the garage door should be lubricated with White Lithium Grease, whether it's a chain or a screw type. Run a bead of grease along the top of it, then run the garage door up and down a few times.
The wheels, track and spring should be lubricated with your favorite lubricant oil -- not WD-40, which is a cleaner and penetrant, not a lube -- but an actual lubricant. I think I usually use silicone liquid wrench.
If the garage door still does not operate, check the alignment of your tracks to make sure they aren't binding. The spring might need to be re-tensioned, which is NOT (in my opinion) a DIY project.
Karl Katzke
  • 7,915
  • 45
-1
Don't lubricate the roller tracks. Only lubricate the moving parts and the top of the rail.
Jon
