Having just moved into a house (from a flat) for the first time in my life), I am about to buy a corded drill. I would like to get something "universal", suitable for drilling the walls to hang a TV or get a cable through the wall into the garden, and also to drill in the laminate and wood. I have a screw driver that I'm using to assemble furniture and do some very simple drilling. But it was already not powerful enough to drill the laminate plate for the heating pipe, I had to borrow a proper drill.
With this in mind, I thought of buying a Metabo UHE 2450. It does just about everything I can think of. It's an SDS-plus hammer, so good for drilling walls and potential garden works. It also accepts both an SDS and a quick-release chucks, to hold all bit types (I have quite a few non-SDS drill bits already). It has two gears, for normal SDS operation and for faster drilling. So a perfect choice.
However, I've just realized it has a 50 mm diameter collar. I've never seen one before, the standard being 43 mm. I'd like to be able to use accessories, something like this drill stand. So I wonder: what can I use such collar for and is there anything like a 50 to 43 mm converter? Or is maybe the path I've chosen wrong for some other reason?
Update: I am in Europe, the walls are apparently from brick (at least outside, potentially concrete inside judging from the first pair of holes I had to make with the borrowed hammer drill, but I've never had brick walls before so I could be mistaken). Drilling concrete ceiling and floors is also a possibility.
texnic
  • 356
You don't want an SDS plus chuck, that drill is going to be mostly for drilling masonry. You could get an adapter to use regular bits with the SDS chuck but it's not what you really want.
There are drills with a regular three-jaw chuck that have a hammer setting for masonry, they aren't as good as the SDS chuck drills in masonry but more than adequate for general DIY use.
I have a Bosch that's been great, but if you like Metabo, I think these are under Impact Drills on the Metabo site:
https://www.metabo.com/com/en/machines/drilling-screwing-chiselling-stirring/impact-drills/
edit: the SBE 900 IMPULS (600865590) IMPACT DRILL actually looks super nice, it has the 43mm chuck you want, apparently its set up to be a good driver as well as drill / hammer drill - that looks pretty versatile, I wonder if there's a US version...
batsplatsterson
  • 25,515
  • 83
Thank you for all input and consideration!
To answer the original question:
I have found a very close question on one German tooling forum. It contains some additional information. Apparently, there used to be stands able to accept large collar diameter drills, including Metabo's Typ 793. However nobody is aware of anything like that existing today.
My assumption: the problem lies in that the large diameter collar is used in hammers rather than drills. They are not designed to be fixed, since they are not designed to be used as drills in the first place. They are also heavy, so the stand should be very heavy.
So the answer to the original question is probably: it does not exist. If someone finds it let them add another answer here.
From the useful accessories for 50 mm collar, Metabo offers a dust extraction set 630828000.
What I wanted to have can be done using e.g. this Wolfcraft or this General's accessory.
Alternatively, there are accessories that hold the bit itself, something like this: Wolfcraft 4640000.
I have also found a very similar tool to the above mentioned Metabo UHE 2450, but with a 43 mm collar: Bosch PBH 3000-2 FRE. However, even from the look, it's clear inferior to Metabo. To my astonishment, it has a plastic collar!
I am afraid, you can't have a cake and eat it, so I'll need to choose if I want a universal drill/hammer or something for a stand. And though the drill found by @batsplatsterson is really nice, I start leaning towards giving up the stand/accessory idea: for orthogonal drilling, there is something like this:
texnic
  • 356
50 mm collar drills where very popular in Europe a few years ago, specially for powerful drills - to drill bricks, concrete, steel... - but, now there are drills with similar power with 43 mm collars...
Drilling concrete or stone with those drills is quite simple (they must have the "hammer symbol" and lets put it on, hold the drill and let it do the job - a good drill will work quite fast with "no pain" for the user, BUT, be aware, those have much more torque then you are used to or you can hold - so, don't push it hard, this way avoids de bit get stuck in the hole (DANGER!!!) - remember, concrete have steel rods in it...
Those drills with the "hammer symbol" (from 1800 to 3000 rpm of velocity), they were not made for stands - they are heavy duty tolls - so grab it, drill it, and it's all.
The ones with no such symbol have (normally) 2 gears and speeds from 150 to 2000 rpm and are specially for Steel (never try it in concrete); those were made for hand hold and stands...
I, my self, have 2 drills with 50mm collar (recent acquisitions)- one for concrete/stone; the other is specially for steel and have the same problem has you, stands for 50mm colars are very hard to find (since the 90s they just vanish - but they were quite popular, has the drills were), even in 2nd hand are hard...
There is a point here that is important to mention - stands with 43mm collars are not made for the torque of 50mm drills!!! And yes! No possible turn a 43 collar in a 50mm... If so, not quite secure...
I'll made one stand for mine ;)
Hoping reaching you in time...
HFeio
