Remodeling bathroom in old house. Water always backed up in the tub. I've replaced the waste lines and pitched them properly. The original line from the tub went under a double floor joist and across 3 others. Should I do something different?
If the drain is sloped correctly per your local building codes (mine state for drain pipes under 2 inches the slope be 1/4 inch per foot) and it is connected to a stack of the proper size (usually no smaller than 1 1/4 inch pipe) then your drain and trap should operate trouble-free. Also be sure the distance from the trap to the vent or stack is correct (in my county any run over 40 feet will need a larger diameter vent).
As far as running pipe through framing members and joists you must be selective on the location to drill a hole through. This depends one the size of the joist and if it has existing openings already drilled into it. If you plan to use a non-drilled joist one opening (again, depending on the size of the joist)is safe. Be sure not to deviate from the starting slope.
- 11,108
- 3
- 14
- 36
