My Whirlpool (bottom) freezer's evaporator keeps frosting, thus rendering the (top) refrigerator warm.
Actions already taken:
  1. Replaced Defrost heater (U-shaped, stove coil-like heating element)
  2. Replaced Defrost thermostat (small "eye" looking thing, with 2 wires, and clips on the start of the cooling coil)
  3. cleaned the coils at the bottom (outside).
  4. Magnetic door strips looks fine to me.
The freezer frosts completely after around 9-days. The temperature will get extremely cold (-16C) and humidity will be around 70%, with the evaporator completely frosted.
What other things should I check?
Rollo R
  • 1,026
Partial frosting is a common sign of loss of refrigerant pressure, i.e. a leak in your evaporative cooling system. You've already addressed the other likely causes of frosting (great!) but that leaves you with the likelihood that it's a leak (doh!).
Refrigerant chemicals are environmentally toxic and potentially hazardous, so at this point you should either have it professionally serviced or replace it (disposing of the old unit properly).
Shimon Rura
  • 8,312
  • 46
