I have an old 3-fuse subpanel (screw in fuses) that currently has two 15 amp fuses and one 20 amp fuse. I want to replace it with a new breaker panel. There is no ground, only hot and Neutral. I bought an Eaton 125 amp load center and I am planning on adding 2 new dedicated lines.
How do I make up for not having a ground wire and/or do I need the ground? Can I use the wiring currently supplying the fuse panel already there? My service is in an apartment and the panel is 4 buildings away so running a new line would be most difficult.
AGar
While the electrical code grandfathers existing installations based on the code at the time of installation, as soon as you start a new installation, you will be required to adhere to the current code. With that in mind, regardless of the difficulty involved, you will be required to run a new line that meets all current requirements (wire type, size, burial depth, etc.) , including a dedicated ground.
If you are lucky, the existing cable is in a conduit, and assuming the new cable will fit (conduit size as required by code), you should be able to pull through a new cable with relative ease.
When in doubt, consulting a licensed electrician is always advisable.
Steven
  • 27,770
  • 56
  • 90
