I've found a property I want to buy, renovate and put a side extension on. The side I want to extend currently has utility boxes on the external wall eg gas meter and I think also the gas pipe entry to the house might be there. What do I need to consider during extension? Can I just build a cupboard around the panels so they aren't an eyesore in the room or do they need to remain accessible from outside the house? Thanks :)
user51001
Gas
The gas meter will have to be relocated.
The gas company may handle the plumbing up to the meter, but you'll be responsible for extending the indoor plumbing to the new location. The gas may be off for a few days, while the relocation is completed, pressure tested, and inspected.
Water
Depending on the supplier and local requirements, the water meter may not have to be relocated. You'll have to ask your specific utility.
Electric
The electric meter will also likely have to be relocated.
As with the gas, the utility may handle the service conductors, but you'll be responsible for anything after the meter.
