Normally the load goes between hot and neutral line.
Since neutral is grounded why can't I put a load between hot and the ground line?
ThreePhaseEel
  • 87,685
  • 144
  • 243
Mleko
Because the grounding system is a safety system, and is designed to only carry current during a fault. If you use a grounding conductor as a grounded (neutral) conductor, you'll have current flowing on water pipes, faucets, appliance frames, metal electrical enclosures, and anything else that's grounded.
Doing this could lead to property damage, injury, and/or death.
