I am using Oatey purple primer with Oatey medium gray pvc cement. This is a 2 inch PVC pipe job for pool pump to filter.
I have a joint where I applied purple primer then realized I am not ready for the fitting so I need to leave it overnight. This fitting is to an ABS filter valve. I realized I need Green ABS to PVC transition cement and will get some tomorrow.
Can I add some fresh primer on the PVC pipe before I glue it the next day with green PVC to ABS cement? Or must I cut off that piece of pipe and start over?
realcoder
yes, you can use it, just re-prime it. You'll see that the fresh coat of primer with melt right through the dried primer.
Bob
  • 2,611
Oatey says the cement is to be applied while the primer is damp.
So, apply a small amount of new primer before gluing and glue after it has dried for a half a minute or so.
http://newsite.oatey.com/Channel/FAQ.html#Q08
Oatey says NOT to use primer on ABS only cleaner.
http://www.oatey.com/products/plastic-pipe-cements-and-primers/oatey-primers.
ArchonOSX
  • 20,870
