I am looking into installing recessed lights in an existing house. Because we have insulation in the attic, I am looking at IC rated, remodel housings. Here in the US, I am finding that the 5" and 6" diameter housings are the most common, but I tend to like better the smaller 3", or maybe 4" models.
Given that context, what are downsides of smaller diameter recessed light housings (3-4"), compared to larger ones (5-6")?
avernet
  • 255
There really isn't any downside that I'm aware of.
Bulbs are a concern, although that applies to any type of light: are they readily available? Can you get them from your local big box store, or do you have to resort to a speciality lighting store, though special order, or from some obscure site on the internet?
Regardless of light size, providing the appropriate number of lights, in the appropriate positions, and with the appropriate bulb beam angle (using flood vs spot) is important. I actually discussed that in depth on my answer here: Is there a good rule of thumb for how many lights you need in a room?
gregmac
  • 29,300
  • 89
  • 162
I usually see the smaller lights used as accent lighting, over a mantle or in an alcove.
I would be cautious using them widely, if only for resale reasons.
uncle brad
  • 416
