I'm running a cold-water pex line in a basement crawlspace that gets extremely cold (i.e. freezing) in the winter.
I'm going to use a drainable ball-valve inside the house so I can drain it in the winter but how can I run the pex line to make sure it's sloped? The run is about 25 feet long.
I think I have two options:
1) Run it through floor joists (requires a hole in every joist since my line is running perpendicular to them)
2) Run it under the joists and use clamps and wood shims under each joist to achieve a slope.
I'm leaning towards #1 but to make sure I have a good slope I think I'll need to measure my holes to make sure the line is actually sloping. For example, I thought I would measure a certain distance from the joist to the floor above to make sure my holes are actually sloping down.
Any other suggestions?
(NOTE: This question is sort-of a follow-up to this: Do I need to angle/pitch pex tubing for draining in the winter?)
Thanks!
SofaKng
  • 393
If you have an air compressor you can plumb in a connector for an air line after the shuttoff valve for the line.
Then leave the faucet open at the end of the line and connect the air compressor with a pressurized tank. This will blow out the line and prevent freezing.
Good luck!
ArchonOSX
  • 20,870
