hi all, what have i done wrong? I replaced like for like (or so i thought) and the light won't work?
Thanks in advance
Your wiring looks correct for the last light in a UK radial lighting circuit wired with the connections in the ceiling rose.
See Ceilling light wont switch off after a new installation
You could
For suitable voltage tester, see When doing electrical work, what do I use to check wires are safe?
Obviously, you need to take extreme care when working in the vicinity of live 240V circuits.
There are three common ways to wire lighting circuits in the UK (in order oldest method to newest)
Yours might be like the last but with two lights controlled by one switch. In which case the wiring you show would be incorrect. Since you rewired like-for-like this is very unlikely.
