I've read to not drill a hole greater than 1/3 the depth of the board (I want to drill a 3/4" hole in a 12" board for wiring, so that won't be an issue) as well as not to do it within two inches of the edges. Mine will be approximately 6" from one end.
Are there any restrictions as to how close to the ends of the board I can go with the hole?
Is the "end" of a joist, one of its "edges" (and therefore any holes must be 2" from the end)?
Mazura
  • 13,598
  • 58
themidnightwill
  • 429
It has to be at least 2" away from the top, or bottom of the joist. As far as distance from the ends, there are no rules:
Holes: Do not bore holes closer than 2" from joist edges, nor make them larger than 1/3 the depth of the joist. –engineering.purdue.edu, PDF
If you look at the document, it clearly states and depicts the top or bottom, with no mention of an "end".
Mazura
  • 13,598
  • 58
Chris
  • 519
