It is my understanding that outlets can have wires connected on both sides. Example from another DIY.SE question here . If I have aluminum wiring. I want to add another downstream outlet. I will use an appropriate CO/ALR outlet. I will verify that the circuit can handle the additional load.
Can I have aluminum wiring on one side of a socket and copper on the other?
I am specifically asking if this AL to CU junction can be handled by the two sides of an outlet as opposed to an AlumiConn or Tyco connector.
Freiheit
  • 4,262
  • 68
The manufacturer of the receptacle should make this detail clear in their documentation. It might even be printed on the case of the receptacle, though perhaps in very abbreviated / "hieroglyphic" form.
That said...
My understanding is that aluminum wiring must be used ONLY with approved mechanical connectors specifically designed for aluminum, and of course must be installed correctly. So I do not see, offhand, why a separate copper connection on the same device would be a problem.
[Note - I am not an electrician. Aluminum wire done incorrectly is a huge fire hazard, which the OP obviously knows since s/he is obviously intending to do this right.]
StayOnTarget
  • 5,675
  • 58
  • 102
