Older homes in warmer climates seem to have a somewhat common smell to them, even after cleaning them. Does someone with experience renovating such homes know what tends to be the cause of these odors?
I am not talking about smells from plumbing, the kitchen or even pets, but the smell that you can sometimes find in wooden sheds, back-country cabins or generally homes built in the 60s and 70s. Sometimes it reminds me of rodents, but only faintly.
I am about to do some renovations, and thought that if this is something that can be included, it would be worth it. For example if this was caused by wood or insulation that somehow got wet in the walls, we could clean out that wall cavity as part of a gut renovation...
nodapic
  • 185
Normally it's the things you can't see.
Moisture building up behind walls or creeping up through micro-fractures in the foundation will cause mold and mildew to grow fairly quickly.
A fairly cheep way to prevent this is to use a powerful dehumidifier to really dry out offending spaces.
Avoid carpet, as no matter how clean it is, will always harbor bacteria that can cause unpleasant odors.
Old insulation can also be a big source of a constant odor that, while to too offending, is incredibly pervasive.
And finally, mothballs. Some people used to use them as a "catch all" solution to pest problems, and used them so much that the very material of the home absorbed the smell, similar to the way homes that housed prolific tobacco users can smell for years after even with deep cleaning.
paas_shill
  • 156
