If I do away with the trap what is it going to hurt? Will something bad happen?
A friend had a problem with clogs. He took his out and has had no more problems. Can you tell me why that is?
The “P” trap (named after its shape, has nothing to do with urine) is there to prevent sewer gases from entering your home. It stays filled with water to form a barier.
You need it. Sewer gases are not good for you. In the right concentration they can even be explosive. Plus they smell really, really bad.
Everything that connects to the sewer needs such a barrier. Some things like toilets have the barrier built in. Sinks do not, so they need it in the pipe.
Your friend will eventually get a clog further down the pipe. This time he won't have a convenient and easy to take apart P trap for whatever crap he washes down the sink to get lodged in, so he will end up having to spend a lot more effort to remove the clog. Cleaning out the P trap (or just replacing it, if it was too gross to be worth saving a couple bucks) would have solved the clog problem just fine.
The p-trap creates a barrier between sewer gases and living space. It's foolish to think you can go without one.
Never remove a P trap.
The purpose of the P trap is two-fold.
Firstly it prevents nasty smells from entering your home through the sink, as water sits in the bottom of the trap forming a barrier against movement of smelly air.
Secondly - and this is extremely important - it is designed to get blocked when people put things down the sink that they shouldn't.
Imagine if whatever it was that blocked it caused problems further down the sewage pipe, underground, or where it meets with the road. These could incur huge expenses to resolve.
So dealing with a blocked P trap is hardly worth thinking about when you consider the alternative.
Better still:
If you rent, it's commonly accepted in most rental contracts that tenants are responsible for ensuring pipes remain clear. Expect a landlord to get pretty annoyed if you let pipes block regularly, as it costs him money to resolve.
It's not clear from your question if he replaced the P-trap with another type of trap, or just removed it completely.
In the US, non-P-trap traps are not to code, because they are more likely to cause a siphon. And no trap is definitely not to code, for the reasons stated in the other answers (sewer gases)
The other reason to have a p-trap: Suppose someone drops a piece of jewelry down the drain. It happens. You'll definitely breathe a sigh of relief if you can recover a dropped ring or diamond earring from the p-trap rather than losing it forever or tearing apart your home's plumbing to try to recover it.
