Our soil/landscaping grade is between about 4" and 8" above the foundation. I've read and been told that this is a problem. I believe the soil should be ~4" below the foundation line. We have a hundred year-old house with a brick foundation.
Fixing it by uniformly lowering the soil line will likely be very costly, as we have a lot of landscaping planted around the house. Furthermore, on one side of the house, if we lower the grade 12", we will almost certainly go below the level of our neighbor's house.
I have several questions:
  1. How significant of a problem is having the grade above the foundation line?
  2. Are there reliable technological solutions that would prevent us from digging up and replanting all of our trees and shrubs surrounding the house?
  3. What kind of professionals do I need to consult to get this done properly?
glenviewjeff
  • 1,479
  • 56
Soil above the foundation means that critters (rodents, worms, reptiles, etc.), bacteria, molds, and water can easily access the siding and infiltrate the walls. Some of these can rapidly deteriorate the structure in a matter of a year or two in contrast to a building lasting 100 or more years.
  1. Are there reliable technological solutions that would prevent us from digging up and replanting all of our trees and shrubs surrounding the house?
Yes. Use a shovel to remove the soil next to the house. You do not have to regrade the whole lot. A foot wide trench next to the house is plenty for this concern, though channeling runoff away from the house should also be addressed. That could be as simple as putting in a few drain lines at strategic points.
  1. What kind of professionals do I need to consult to get this done properly?
I would start by looking around your neighborhood and see what works and what does not. Imitate the successes.
wallyk
  • 12,399
The original question ended up being a moot point as written. It hadn't occurred what it meant to me that our foundation is brick. We have brick foundation and the brick extends up above grade by about four feet.
What had me confused at the time I wrote the original question was that the brick is parged with a thin layer of concrete below grade. This was apparently done by a previous owner to mitigate deterior brick rather than replacing/repairing it. The parging threw me off and isn't relevant.
glenviewjeff
  • 1,479
  • 56
