My next door neighbor decided to saturate panels of our steel fence with cooking oil to stop the rust (which was expected and is a desired patina).
How can we get rid of the old oil smell and get the oily stain off the fence?
  • 20,909
  • 95
  • 135
Debbiebeth
Knowing that you don't mind the rust, I'd go at it the same way you would dirty dishes soiled with the same thing--dish detergent and water. A little scrubbing with a nylon brush shouldn't damage the surface, and the rust will return shortly.
You will want to use something that is non-toxic and biodegradable since it is outdoors.
I would recommend using car wash soap, and wash it the same way as you would with your car. It has degreasers in it, and is usually safe. Mix a small amount with hot water, and scrub the fence with a stiff bristled broom. Spray the fence with water, and then scrub with the soapy water and let it sit for a few minutes, and then rinse.
You may need to repeat a few times to get all of the oil off. A pressure washer will speed up the process.
Jason Hutchinson
  • 3,532
Most solvents will remove oil. if you really want to strip the oil quickly brake cleaner is amazing and bare metal starts rusting quickly after cleaning with this product. I use it quite a bit and it is one of the best degreasers I have found.
Ed Beal
  • 103,727
  • 79
  • 158
Simple Green is a degreaser, it's biodegradable and non-toxic. If you could stand up a sheet of 4 x 8 plywood behind the fence and hit it with a power washer, that'd be great (probably). But if not, apply some good ol' elbow grease.
Xavier J
  • 121
