I'm installing baseboard on the outside of a staircase in my home. The staircase doesn't have an open stringer, and the height of my baseboard has created a really interesting angle at the bottom of the stairs where the floor meets the first riser.
Outside Stringer Baseboard
This cut has completely broken my brain. Any insight on how I can find the angles to wrap this around would be really appreciated!
Jared
From your picture, it looks like if you extend the non-flat sections of the moulding they'll intersect before you reach the vertical at the end of the stair (e.g., pardon my abysmal Photoshopping):
This would certainly be the easiest solution, although it may not be the prettiest one.
Daniel Griscom
  • 6,319
  • 43
I'd be tempted to put a piece of blocking in to pull this out a bit, to avoid the long awkward angle (just because it would be really hard to get that cut perfectly).
You can use a piece of molding similar to the baseboard (different height maybe) or something more wood-grained to match the stairs.
gregmac
  • 29,300
  • 89
  • 162
