Will constantly turning the power off/on manually (one to four times a day) at the circuit breaker box cause any damage to the box itself or to the wiring in the specific room and will it most likely result with a higher utility bill?
Asked
Active
Viewed 52 times
As long as the breaker is rated as switch-duty (SWD), there should be no problem switching in ON/OFF many times.
- 80
- 327
- 617
Right. The only foreseeable problem you could ever have with this procedure would be wearing out the breaker itself over a period of time.
Randall Wilkinson
- 37
- 2
