I bought 31 thujas a couple of months ago and some of them are really struggling. I installed a drip line a week ago, but am wondering if these trees are completely dead.
Here are a bunch of pictures. Click on them to see larger views.
enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here
Is there any way to bring these back?
Kirk Ouimet
  • 415
Of the eight pictures only the third picture shows a cedar that will look good. The rest are either dead or so badly damaged it would take years before they looked good.
This kind of dieback is often seen when they are not adequately watered after planting or when stock is planted late in the fall and doesn't have a chance to root before winter.
Arborvitae or cedars prefer a soil rich in organic matter that is not dry. A thick mulch of two to four inches (up to eight cm) will make a huge difference in the success of the plants.
If you happened to have a downspout nearby you could divert the rain that would normally drain off to the street and water the cedars. By using a four inch drain pipe with sleeve in a trench next to the cedars you can water your cedars while sitting in your house.
kevinskio
  • 62,221
  • 167
Your trees are in very bad shape. Most of them will take quite a while to recover, if they do. At this point it would be suggested that you replace them. It's always best to plant these in the spring, before new growth begins, and the sun is less intense. The cooler temperatures and shorter days will relieve some of the stress. Make sure the plants stay well watered until established. These trees are resilient, but can't dry out before being established. Also, fertilizer will induce some growth, and cause faster root growth, to speed establishment. Pretty much, if you can see more than half brown on a conifer, replacement is the fastest road to success. A couple of your plants look fine, and you could save those to be easier on your checkbook.
J. Musser
  • 52,241
  • 122
  • 333
Ouch! What an investment you've made. I am sorry. All but the totally green ones will not make it. What kind of soil is in your terraced beds? What is your irrigation schedule? What did you use for fertilizer, soil ammendments? What is the orientation of these beds. Did you buy these in pots or b&b? Let us help you to not make this mistake again.
Send pictures of the entire project. Arborvitaes will not live long in such a small area, there are better plants that would do similar growth habits but thrive better than arborvitae in such a small area. Much better plants than good ole overused arborvitae!
stormy
  • 40,664
  • 76
These are planted very very close to either the fence or property, whatever it is. They will be in the rain shadow, and will likely as not, get only a hint of natural rainfall. If they are against a fence it's less of a problem than if they are against a property with foundations and it looks like against a path also with foundations. Neither of which will have water bearing soil, they and any replacements are likely to be in very small parched soil pocket/trench that will require constant monitoring for watering. Recommended planting distance from any structure in a similar way, should be 12-24" as a minimum I would think.
