18
It's said that we shouldn't use manure when preparing ground intended for carrots. Is it that carrots don't thrive on manure, or is it that they fork and splinter too much?
What about other roots? Radishes, beetroots etc?
bstpierre
  • 41,932
  • 118
  • 240
Tea Drinker
  • 9,643
  • 114
5 Answers5
18
The root cause (no pun intended) is that excess nitrogen will make the roots fork. I've heard two different theories as to why:
  1. "Hot" fertilizer like fresh manure burns off the fresh roots and makes them fork.
  2. A lot of nitrogen in shallow soil fails to encourage the plant to scavenge deep in the soil for nutrients, and they send out roots sideways instead.
Or it could be combination of the two -- but the latter came from a more reliable source and fits more with my experience. (One of my books versus something seen on the internet -- sorry I can't remember exact sources.)
Even in soil where I haven't added extra nitrogen but was very fertile with other nutrients, I have seen carrots develop not so much forked roots as fat sideways roots instead of the usual fine "hairs".
bstpierre
  • 41,932
  • 118
  • 240
14
Fresh manure can cause carrots to fork. If you use any fertilizer, make sure it's well-rotted manure instead. (source)
I've read that the same goes for beets as well.
Doresoom
  • 2,562
  • 25
I grow carrots and I don't believe roots branching off has anything to do with manure.i use kelp for manure. I sift my soil and mix it with sand and I have perfect 16 to 18in carrots every time with no roots branching off. Prior to doing this I didn't sift my soil or mix with sand and my carrots had branches everywhere. I think the branches on carrots are caused by hard soil
Ben
  • 71
Fresh manure also can transfer E. Coli to garden vegetables, so you should always make sure your manure is well composted, for around 3-4 months. If it's still smells very strongly, it's probably too fresh.
Leads to forking of the tap roots (which are the carrots) Leads to high vegetative growth leading to small tap roots (carrots)
