19
This is my first attempt to grow something and it hasn't started off well. During the last winter, my Persian lime tree wasn't protected well enough from a cold front. All the leaves fell off, and the bark became brittle. I assumed it had died and was planning to uproot it in the spring.
When spring came around, I noticed at the very base, almost even with the soil, new leaves began to sprout. Today, even though there are 5-6 new branches forming,they are only at the base, and there is no sign of life on the rest of the tree.
  1. If I take care of it, will it eventually recover?
  2. Will it ever bear fruit again (Someone told me no).
  3. Should I cut away all the dead parts?
  4. Would I'd be better off replacing it.
Also, the tree was young to start with, only 4ft tall or so, but did bare a few limes before winter. Thanks!
Edit for clarity: My main question and concern is, if I choose to nurse the tree back to health, is there any possibility the tree will never bear fruit again? I had a person tell me that could happen, but I can't find any evidence to back that claim. If there is a possibility, then with the plant being so young, I might be better off starting over. Heh, I guess I feel bad for killing it and would like to see it recover.
I live in the U.S in southern Louisiana. Winters don't usually get below 20F here. I'd say average winter temp is around 50F.
Pictures Picture of entire lime tree Picture of the base of the lime tree
Lorem Ipsum
  • 11,219
  • 58
  • 95
csthopper
Don't bother; really. You likely have a bigger problem.
Persian limes are are sterile triploids, hence no seeds. What that means is the tree itself is a hybrid which was grafted onto the rootstock of a completely different citrus variety.
What that means to you is that there is a very strong chance the shoots are coming from original tree stock and you will not end up with a Persian lime tree.
There's no telling what you will end up with, even if it does manage to bear fruit. I had an orange tree that "suckered" from the wild rootstock… and the oranges it produced were closer to the essence of turpentine than anything resembling an edible orange.
Do yourself a favor: Get out your loppers, close your eyes, and give the remains a proper burial (but don't really close your eyes as that would be very dangerous). If you're essentially starting from scratch anyway, at least start out with a healthy, new tree. You may even consider looking into a variety that is just a bit more cold tolerant for your area.
Robert Cartaino
  • 2,573
I can't answer all 4 of your questions, but please allow me to answer the ones I can.
  1. I honestly believe, no one can really tell you that for certain without actually seeing the tree in question (or at least a few photos).
  2. Pass.
  3. Yes, without question. Any dead parts on a tree should be removed immediately (ASAP). Failure to-do-so greatly increases the chance of pests and diseases moving in and infecting the tree. When removing dead parts, make clean cuts (using appropriate pruning tool for the job at hand), leaving a small part of the branch collar visible at the intersection of the trunk. Never cut (hack) into the trunk of a tree, unless you have to remove dead, infected parts of the trunk itself, then if it's that bad I would recommend calling in a specialist ie An arborist.
  4. Without actually seeing it, or least some photos of it, it's a little hard to say.
Appropriate pruning tools for trees:
  • Pruning shears, up to 1inch (25mm) diameter
  • Lopping (long handled) shears, up to 2inch (50mm) diameter
  • Variety of hand saws, from 1inch (25mm) up to 4inch (100mm) diameter
  • Chainsaws, from 2inch (50mm) up to felling giant Redwoods, Sequoias. Best left to the pro's when using this dangerous power-tool.
For an excellent resource on how to prune trees, take a look at the following document from the US Forest Service:
Mike Perry
  • 18,467
  • 48
  • 90
Our Persian line was in a pot that I moved into a shed for winter. Lots of windows. A hard freeze and the tree was in bad shape. A year later, it definitely has lines on it and many white flowers. So it seems it did not freeze badly? Will let you know how the fruit is tasting.
